Swap CW instead of WW
I have a set of Lumary pathway lights that work with SM16825 but CW and G are reversed. Swap only allows W to be swapped. Anything I can do? Is there anything JSON I can do to swap them?
Aah, so this is dead in the water I guess. That’s a bummer.
You can modify source and compile your custom version.
EDIT: Or upvote by providing details of your strip.
Happy to collect info, just don’t know how. I opened one of the lights up, but the IC is covered in compound to keep it waterproof. I can see that the LED itself is all in one. It’s a square RGB with a CW section on the bottom and a WW section on the top.
Is there any way to look anything up via an FCC listing?
