Switchbot floor lamp wled conversion
Can the switchbot floor lamp (matter version) be converted to wled?
Lamp specs found on the site
If it uses a compatible ESP as a controller it probably can be used if you reverse-engineer all pins used. Or fully replace the controller but hard to say without opening it up and checking what LEDs and controller was used.
I was thinking of fully replace the controller with a gledopto one to make things easier for myself so i wanted to know if the led bar itself could work
