I have setup a ESP32 (WKED version 0.13.1) with two stripes.
I want to sync the state of the leds from stripe 1 to stripe 2 so it is a complete mirror.
E.g LED 1 of stripe 2 should show the same colour and brightness of LED 1 of stripe 1, LED 2 of 2 the same of LED 2 of stripe 1 and so on.
Is this possible within of WLED and if the answer is “yes”, how?
Tonyno is telling you the practical way of doing it which we use also . if you want to keep two output then check Custom bus start indices , it works as it will look as one strip but I do not recommend it and I just did it to test for you
@tonyno: Sorry I missunderstood your first answer @ALDIY : I will give it a try.
The whole setup is a little bit complicated. Both strips should illuminate a living room. One on the left wall and one on the right wall. The right one does not have the exakt length of the left one, because there is a door in the middle of the wall. I will try it with the custom bus start indices with the mapping feature.
