Hi everyone ![]()
I completed my setup and i run everything it’s all good
But when i shut it down from the plug
and turn it on again the bord losses it’s connection with the wifi
the bord is ( ESP32) and the software model is 13.0
By completed your setup I assume you connected that to your home router and have an ip assigned . If that is the case and your unit no longer connect to wifi after power down then that is not normal .
The version 13.0 is ancient so first thing to do is install latest 14 build from here ( since your version is old ,OTA might not work with you so best to flash with usb )
WLED installation (wled-install.github.io)
Thank you for your help
I will try your idea ![]()
