Turning off wifi when using ethernet
is this possible?
I want to reduce the amount of radio waves flying around as it is causing conflicts on my network and the DCHP of the router can get confused as each ethernet node connects twice.
I’ve tried removing the wifi SSID and password from the settings page but it just doesn’t connect and opens a AP…
the instances are showing up in the instance list and my routers’ list of connected devices but i cannot actually connect to them
there were a few things going on at once here solved it now by
  • making sure the router is doing the DHCP and not the nodes
  • make sure the MDNS box is also empty
