Turning signals for a vehicle
Hello, i read on some posts about turning signals and i found some people that tried that, but i didn’t find if they got it to work. So i have the esp receiving signals from the vehicle turning signals and i want to make a an animation when turning signal is active, i can make that with playlists, but if i want it with an off effect, so when the turning signal will end the segment will switch off and fade in back to DRL.
The problem comes when i want to make the other side, if i signal left for example and quickly change to right the playlist will be changed and the left one will remain with the signal effect or even off, because the playlist will not be finished and a problem with the hazzard that wled doesn’t know anything about two buttons press at the same time and it cannot cancel both effects and make the fade, it will only make for the last press detected, so only one will turn off.
So with this i thought i can make an usermod for that, i managed to do the hazzards and things to be detected but i ended up with the same problem, playlists cancelling and not being able to return back from quickly changing signals.
I managed to make the signals without presets by making the effect inside the usermod with a transition to the DRL, but i didn’t had any time to finish both sides and hazzards detection.
My question is if i can handle such thing in another way or use something to help me achieve what i want because i don’t know very well the platform and the system itself.
welcome there is a projekt already finished for this issue
search for bicicle lights
here is the POST
