Did anyone manage to get this type tuya/ lsc (lsc is rebranded tuya) festoon lights working on wled?
You probably won’t be able to use the built-on controller. Connect it to an esp32 and you can use wled
Does wled support rgbIC ?
Yes, it works with many ic chips
As much as I know it uses a RGB addressable Mode but white Only works on PWM.
