Two separate white brightness slider
Hi, I have configured an Esp32 with a analog white LED (PWM white) on the first pin and on the second pin a Sk6812 RGBW LED Strip.
The configuration works fine.
My question is:
The white brightness slider change the value from both white LEDs (PWM + Sk6812 ) together.
Can I configure a second white brightness slider? So that the PWM has an own brightness slider and the Sk6812 for the white LED an own brightness slider.
Set them up as separate segments.
