Hi.
this is my first time using WLED, I already have around 20 tasmota devices running without any issues.
I have a Wemos D1 mini flashed with latest beta build 0.14.0-b1, Signal Strength is 100% (-46dbm). I have random connection issues. When I open the WLED Webserver I have sometimes messages that WLED is not reachable. I set up a Uptime Kuma Monitor to ping the device every 20 seconds:
I already flashed WLED twice with erasing but problem remains, I also flashed tasmota on it and that worked as expected and commands were applied instantly.
I have a 5m 300 LED strip attached together with a 100W power supply with 2 joints at start and ending of the strip, Power measurement turned out that a maximum of under 80W is used so there is enough power for the D1 available. The D1 get its power from the power supply directly.
I couldnt find a serial output, console or Log Output at all so I really dont know how to debug this problem. Any hints or recommendations how I can solve this ?
