First of all I would like to thank the creators for creating such an incredible open-source platform!
I installed wled on a WEMOS D1 Mini Lite v1 with a 1m 60led WS2812B Led strip. Everything is working perfectly except for the fact that whenever it disconnects from power the WiFi settings as well as the Led configuration settings are undone. As a result after every reboot I need to connect to the Wemos d1 via wifi “WLED-AP” and I need to retype the network and led settings. How can I fix this? I’ve tried reflashing as well as using older versions but with no success. Is my wemos a really old model? Am I doing something wrong with API? Any help is greatly appreciated! Thank you!
I fixed the problem! It turns out that the Wemos D1 Mini Lite has 1MB of flash storage so I simply had to flash it with the _1M.bin file!
