Which case can be used for WT32-ETH01?
Hello.
I will have 5 meters of addressable CCT tape at 24v and a power supply at 24v.
Thank you.
I designed this:
Choice of round DC connector or panel-mounted XT60, and space for a 8.5x13.5 switch
https://www.aliexpress.com/item/1005001485034492.html
https://www.aliexpress.com/item/1005002588435794.html
https://www.aliexpress.com/item/4001032036059.html
I tape a regulator like this for supplying the ESP from the 24V, enough room to attach it inside with double sided adhesive foam
https://www.aliexpress.com/item/1005005919024149.html
wt32-eth01 case.zip (107.9 KB)
Thanks a lot.
Did you additionally solder resistors and capacitors, as is recommended everywhere?
As I understand it, your tape is 24v. Do you power it directly from a 24v power supply or from a controller?
I added the 1uF ceramic cap between EN and GND to make boot reliable and of course used a level shifter, there’s room to tape one at the bottom of the WT32 (the ones pictured aren’t great though, see recommendations).
Powered directly by a power supply.
Thank you.
I can ask you, if it’s not difficult, to draw a wiring diagram for everything you have. I’m not an electronics engineer, so it’s difficult for me to understand the entire wiring diagram.
If it’s convenient to draw on paper and take a photo, or in paint.
WLED documentation has those.
