Is it necessary to use LED Driver Board for WT32-ETH01?
Hello.
I’m new to electronics, I’ve never assembled esp/arduino.
I decided to build an address strip with an ethernet controller, without wifi.
I settled on WT32-ETH01.
I’m planning to build a light like this:
  • WT32-ETH01 with WLED firmware
  • LED strip 5 meters at 24v ws2811 CCT FCOB 10w/m
  • power supply 24v 100w (or 72w)
  • power supply 5v 1a
I plan to power the tape directly from a 24v power supply.
The question arose: is it necessary to use additional expansion cards such as
WT32-ETH01 - WS2811/WS2812 LED Driver Board - WLED - FastLED - 5V/12V
4 Channel 30 Pin Node-MCU ESP32 - WS2811/WS2812 LED Driver Board - WLED - 5V/12V
If there are any others, please tell me which ones?
Or is it possible to connect the tape directly without these boards, as in the diagram?
Have I connected everything correctly in the diagram?
Is this where I connect GND from the LED strip to the controller?
You definitely need and level shifter Other Hardware - WLED Project
+1 on a proper levelshifter, either of the boards you linked should work.
Note, those are just header boards, they don’t include an actual ESP32.
Also the 1st is designed specifically for the WT32-ETH01, the 2nd is for another common series of board. You’ll have to check the pinouts to see what works.
The general idea of powering the MCU from its own power supply is good, you just might want to choose a 2A or even 3A 5V supply. The WT32-ETH01 boards have been known to be somewhat power hungry.
Are you talking about SN74AHCT125?
I didn’t understand where this chip would be connected.
Screen_2023-12-10_12-04
From your previous links, both those boards have the '125 chip builtin. They have it wired on 4 of the GPIO outputs to raise the data level from 3.3V (standard ESP) to the 5V TTL that LEDS require.
It’s already handled with those boards.
