I have several Wemos D1 mini boards (ESP8266) currently working fine with the standard WLED 13.3 compile.
I ordered 2 of each of these and would like to get them working with WLED.
https://www.amazon.com/dp/B08J2FPK99 (SSD1306 128x64)
https://www.amazon.com/dp/B08F9F8BYB (SSD1306 128x32)
@srg74 will your “display” custom compile
work as-is with SSD1306 128x32 & 128x64 OLED displays available on Amazon?
What OLED i2c address is set in your custom compiles?
The SSD1306 128x64 OLED displays have 2 jumper-selectable i2c addresses.
The SSD1306 128x32 OLED displays do not indicate what their i2c address is.
I read here that the base addresses are 0x3c
I expect I’ll need to use the same i2c pins used in the Wemos shield.
Shield pinout: For ESP8266 based boards:
- GPIO5 - D1 - I2C SCL
- GPIO4 - D2 - I2C SDA
Thanks for any help.
