Wipe effect issue
Hello
i have an issue ith the wipe effect on weld (version mm 14.5.0-beta).
color1 white (it is the same with other colors)
color2 black
the effect only seems to affect the first 2/3 of the strip where the wthite wipe and replace the black, but the last third of the strip stay black.
If i use other effects (like solid) the whole strip light up correctly
each light is connected to a different gpio and they eachconsist of 2 sk6812 strip (144 led each) with the dataline in PARRALEL (so for wled it is only 144 lead per gpio)
what i want to do is just to have the wipe effect use the full lenght of the strip.
changing the speed and intensity of the effect does not solve the issue
one workaround i found but work only for the segment 0 is to change the end led to something bigger like 250 and it work on the segment0 (but i cannot do that for segment 1 as the last led configured in wled is 288)
link to video https://youtu.be/Xq1OcQd-n5A
thank you for your help
Try setting your color palette to default.
omg it work!
thank you a lot
