I have a wled project that is using three “keeYees esp8266 ESP-12E CP2102” controllers running static IPs on my wifi with no AP. The dbm rating of my wifi access point is -36dbm. For whatever reason the following repeatedly occurs:
- Cannot find controllers when discover controllers is used on the wled app. (I add them manually to add them at all, thus the static IP)
- I receive “device unreachable” or “loading wled ui…” when I try to access any settings on the app for the devices.
The following is working: - Turning off/on the leds and adjusting brightness via app
- Wled device can be seen as connected to my router
I have tried the following: - Pinged the device, it looks like 50% or so of pings are not going through
- Tried disabling wifi sleep, didn’t help
- Tried disabling wled AP, nothing changed
- Tried accessing the wled devices from a computer, still shows as loading or unreachable
What am I doing wrong? Is there some setting I have missed or misconfigured? Could it be the esp8266 controllers themselves? Would switching to esp32s make any difference?
Anything else I can do to troubleshoot?
