Currently supports upload and download images and multiple wled devices. Also takes care of the different sizes … but it has to be a 2D matrix.
Planned: gallery (save & load in the browser), update import, text rendering, animations (maybe), and Home Assistant integration (very very far in the future)
I think it serves a slightly different use case. Having the editor directly on the WLED device is perfect when you’re working locally with a single controller, for example at an installation or venue. I will definitely use that, when I am with my company at events or venues.
My main use case is managing multiple wled matrix displays across my home. I wanted a simple way to upload an image, select one or more displays, and send it directly — without installing additional tools on each device.
Both approaches complement each other well depending on the workflow
yea a multi-matrix managing tool for on-the fly image display would indeed be useful for some cases.
My focus was on easy-to-use and install for typical WLED use cases - which is 1D strip setups for home lighting as well as nice layout both on PC and mobile, fast live-streaming without the use of DDP.
theoretisch ist die Matrixgröße nicht begrenzt – solange dein Browser mitspielt
Bei größeren Formaten (wie 64 × 48) bekommst du im Editor einfach Scrollbalken eingeblendet, damit du die gesamte Fläche bearbeiten kannst.
Eine 64 × 48 Matrix funktioniert problemlos. Bei größeren Flächen werden im Pixel-Editor automatisch Scrollbalken angezeigt, damit der gesamte Bereich bearbeitet werden kann.
LG
Inf0
p.s.: gestern gabs die Scollbalken noch nicht Danke für die Idee!
just to clear up a small mix-up: this thread is about WLED Pixel Studio. PixelForge is a different tool — it’s the one that now ships built-in with the latest WLED version, so I’m not the right person to help with it here.
For your issue (gif/photo/video files greyed out in PixelForge on a Samsung phone), I’d suggest one of these:
search the forum for PixelForge and post in that thread,
ask on the WLED Discord, or
open a new thread describing your problem.
That way the right people will see it and you’ll get a much faster answer. Good luck!
