Hi All,
as all others before myself reported … amaziiing work at all.
I rolled out the WLED also on normal 12v rgb stripes with additional solder a esp 8266/esp32 on top of the normal 12v controller… to transit a normal 12v led rgb or rgbw stripes to work with wled. It needed some step up step down modules but all in all it works great . the most good one is- I have at home now all LED controller running WLED firmware which makes it easy to work with dmx as well. Remeber by RGB stipes to set in ledfx more than 1 led otherwise it will not work - i faced with that problem and could solve it to switch to 10 leds in wled config and ledfx config.
I just have one open question:
can I use a normal 2 m sting of leds and add at the end a neopixel ring as seperate segment? O would add to an existing controller the ring as a analog clock but would have 2 “virtual” devices; one is reactong on segment 1 and 1 as segement 2.
can anyone tell me if that is possible?
thx and enjoy your creativity,
v0r73x
