WS2811 LED Limit
Hi. WLED newbie here. I have 3 strings of 50 WS2811 LED’s running from an ESP32 board. I have set the LED preferences to 150 LED’s but for some reason, the last 6 LED’s on the run do not light up. It doesn’t matter which way I arrange the strings so I know it’s not faulty LED’s. I have read that I should be able to run 150 LED’s without power injection, but is this not the case?
Thank you for any help.
Check your segments and make sure they are the correct size. If they are correct. Post some pix of your LED Pref’ screen so we can have a look.
Thank you! The segment stop LED was set at 144.
Thanks for your help and thanks for the quick response.
