My bug is simply randomly losing some of the pin assignments and altering the led numbers per pin output, also glitching when driving more than one set of WS2813-E as I understand there is a reset timing issue similar to WS2812-C I need to fix this asap, for now, I suppose I will need to reinstall generic Chinese controller to get us by? I can recompile myself although I don know where to adjust the timing?
Please see below
total LEDs 350
output 1
Pin 32
Start 0 count 70
output 2
Pin 33
Start 70 count 130
output 3
Pin 25
Start 130 count 175
output 4
Pin 26
Start 175 count 225
output 5
Pin 27
Start 225 count 280
output 6
Pin 14
Start 280 count 350
after the power cycle the numbers change but not all of the time I have tried 3 different boards now to no avail
mainly the led numbers change for instance
output 5 changes to start 225 and count 225
and 6 start 280 count 70
and sometimes the pin numbers end up being null ie no contents
and occasionally it will lose everything and return to defaults ie pin 2 etc
i have checked flash and cleared it multiple times
Expected behavior
To retain settings
WLED version
- Board: [ESP32 dev]
- Version [latest precompiled binary for the esp32]
- Format [Binary]
Additional context
Please help asap I have rather embarrassed myself making a boat sign for my friend
originally we used an SP608E controller and that had a glitching problem that I solved with 500r resistors just ahead of the first led in a chain. but I wanted to use wled, as soon as I found out you can do 10 channels with esp32 I wanted to change over… I started off by putting a logic level shifter inline bassed on the TX5018E and it glitched like crazy so I tried it right at the letter input without 1.5m of cable and it still glitched, I then bypassed the logic level and went straight to the esp output and it seemed to work for one letter so I went back inside the boat and attached them all bypassing the level shifter and they glitched again, please remember the 500r resistor is still inline would this cause an issue?
Thank you for your help!
