I tried, to run ws2814 (24V Stripe from BTF) as SK2812 RGBW on a WEMOS D1 ESP8266 with Installed version: WLED 0.14.0-b3
(esp8266 build 2306180)
Settings:
SK6812 RGBW
Color Order: BRG Swap: none
Raw it’s working, but blue and white are changed, and if i try to activate swap w & b and press save - it’s all te same. Swap none
I did also tried the beta 14 b1 and release 13.3
Is anyone her with succsessful run this combination?
I’ve found the solution
With the Onlineflasher I had the described malfunction.
Do I use ESPhomeflasher 1.3.0. (1.4.0. doesn’t work) it’s fine.
Beta 14b1 does work,
Beta 14b3 also.
After this I tried Onlineflasher again. Now I can control settings over Onlieflasher and with cellphone App and it works fine.
Don’t ask me why, it hungs before
Settings for WS2814 RGBW Stripes are: SK6812 RGBW
Color Order: BRG
Swap: w - g
I will care now, to make it electrical stable (EMV problems)
