3D palm-sized props built from custom PCBs
This is a series of experiments with 3d lighting elements built from PCBs. The physical pixel layout is basically a spiral from (arbitrary) top to the opposite bottom.
The dodecahedrons with 20mm and 27mm edges are big enough to hold a LiPo battery and charger + WS2812B controller, and I’m working on an icosahedron version. I got some assembly jigs made, but with the later versions with tabs and slots, the jigs aren’t as necessary.
I’ll update when the modules are working. They feature 6-axis accelerometers for sensing movement.
Ready to slam into the Haloween LIGHT 2024 Worldwide Market
Is this also waterproof to get them along the Gardenway in light Snow Cover 1Inch
You are selling products somewhere?
These were inspired by cube mood lamps, based on LED rings, that someone was selling at a maker’s fair. I of course decided to do one better.
These will probably go into globes stuffed with some kind of diffuser, glass wool or similar. Need to come up with a mount for the USB jack. Or maybe without a globe, cause they are kinda of cool to look at and hold. OTOH, the problem with items for outside is always the enclosures.
Anyway, this project is very much a work in progress.
Prototype icosahedron (= 20 faces), and then stuffed inside a plastic sphere with (somewhat dirty) insulation as padding/diffuser. I should be able to do that better. I’ll also try with 120 degree lenses on the LEDs.
