Hi All,
I seriously need some help i’m struggling and i somehow managed to fry a couple of strips. Here is my hardware:
- Wemos D1 MIni
- These LEDs: https://www.amazon.com/gp/product/B01CDTEJBG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
- Power Source 1: https://www.amazon.com/dp/B01D8FM71S?ref=ppx_yo2ov_dt_b_product_details&th=1
- Power Source 2: Facmogu 2 Pack DC 5V 2A Power Adapter, AC 100-240V to DC 5V 2A 10W Power Supply Transformers, 5.5 x 2.5mm DC Jack Also Compatible with 5.5x2.1mm Socket on Amazon
I tried to wire the lights directly from the D1 mini, and through two different power sources which are listed above. In all cases i went form the 5v/Positive to the 5v on the LED, GND/Negative to the Ground on the LED ,and GPIO 2 (D4) to the data on the LED. In all three cases the LEDs didn’t even register that WLED was attached and either shined super bright white, or only the first light turned green.
Any ideas?
Thanks Everyone.
