Install.wled.me fails to open serial port
Hello! This is my first adventure into this space, and I seem to have hit a wall on step 1…
I have connected my ESP8266 to my computer and clicked install. My ESP8266 appears in the window. When I select it, I receive the following error:
“Failed to execute ‘open’ on ‘SerialPort’: Failed to open serial port.”
My online troubleshooting has gotten me nowhere. Any help getting past this error would be much appreciated! Thanks in advance!
You either don’t have the correct driver installed or are not using a data usb cable. Depending on what serial chip your board has on it, you would either need the ch340 driver or the CP210x driver
Reboot after installing the driver
@Jinx Thanks! Turns out it was my cable…
The installer is able to connect; however, the box popped up saying “Installing WLED Preparing Installation” but the blue circle just spins and spins.
I have removed and reinstalled the CP210x driver and tried multiple different cables but still get the same result… Any ideas?
This is resolved. Not sure what the issue was, but I was able to manually flash the chip using PlyFlasher. Everything appears to be working now. Thanks again for your help!
In my case, it was because I had Ultimaker Cura running and it grabbed the serial port as soon as it was plugged in. Exiting Cura allowed the install to proceed.
Jack is a spam bot. Don’t click their links.
I have done nearly hundreds of WLED installs on ESP32’s BUT, holy SHIT! I had to fumble with a forgotten Discord password for about an hour and take the time out of my day just to respond to this. I would have NEVER figured it out until Cura possibly happened to be closed one day, which is basically never since I am 3D printing 24-7. I closed Cura and BAM, WLED installed. Thank you thank you THANK YOU.
Saved me a lot of time, wouldn’t think of it. Thank you!!
thanks so much! had been tearing my hair out for way too long…
Thanks for this. this was exactly my problem.. not sure I’d have ever thought of it.
