Hi everyone, looks like a really cool bit of software you have here.
I’m putting together a project that uses 12 poles 1 metre apart. Each pole has 70 LEDs and a UART controlled Voice playback module (DY-SVR19R).
I’ve got a bunch of ESP32 modules from a old project so I was wondering if I could attach a ESP32 to each of those poles and control them all from something like a Raspberry Pi via the json API and presets?
I can see from other usermods that getting the ESP32s to send a UART command should be possible. The 12 metres will be outdoors and unobstructed so a router should have clear view.
I guess the real question is should I do it over just connecting all the poles to a Pico and Multiplexer and just using something like FastLED. Would there be a lot of latency and other issues? I guess I’m just trying to save time on the wiring and coding.
So the idea would be that the raspberry pi sends a Json to a ESP32 to play a certain preset.
The preset would be just an LED animation and to send a UART command to the voice playback module to play a certain track.
It would still need the power wiring but it’d cut down the use of the multiplier or relay to control so many UART connections. It’d also mean I wouldn’t have to worry about trying to send a command 12 metres from the pi to the to the voice playback module.
I assume the LED animations between the poles would be the hard thing to sync correctly
