Quinled-dig-uno v3 - relay 5v pin
Hi All,
Trying to get a relay connected on the v3 quinled dig uno, but having issues as the 5v pin is now under the ESP32. Has anyone else run into this issue and how have you got around it?
Thinking about just soldering to the pin, but trying to avoid that if I can.
Thanks,
Karl
It’s true the Q pins and such moved to a double block but you should be able to squeeze dupont wires in there, it actually helps them stay put better. :innocent:
Lol, I had to bend the pins to get it in, but it will stay there now.
