i found now time to play a little bit with your code, i found a problem.
when i use the full brightness, he has problems by the wipe_down (reverse) effect when a solid is activated before.
you see here in the first seconds it is blue.
the code:
{“on”:true,“bri”:255,“transition”:7,“tb”:0,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:144,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“n”:“stair1”,“col”:[[0,0,0],[203,219,255],[0,0,0]],“fx”:3,“sx”:200,“ix”:255,“pal”:0,“sel”:true,“rev”:false,“mi”:false},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
(by the way why he makes 100 stops?)
when i now choose the led off before i use my wipe_down present it works
or it looks that he skips the first leds?
here is my selected color and palette
EDIT
Okay i see in your code you set “transition” to “0” in my code it was “7” , when i change it to “0” it looks much better.
