WLED-AP Wi-fi set up. please help
hi there. when i flash my ESP8266 then connect to WLED-AP network to update my Wi-fi. it gives me…
This information is not secure
This information will be sent in a way
that is not secure. Are you sure you want
to send it?
When i click send, it goes to
Wi-fi settings changed
But it doesn’t ever change or connect when i go back in to check. Any idea what may be the issue? please hell
Have you tried using the website install to change the Wi-Fi settings?
That’s usually my go to if I have any connectivity issues. I usually just connect it to my computer open up that webpage start the first part of the install, give it a few seconds and usually the connect to Wi-Fi option will show up. From there just input your wi-Fi credentials. I placed the link in the bottom. Good luck.
https://install.wled.me/
