I have wled on esp8266 nudecum but it doesn’t connect to wifi what can it be? I’ve re-recorded 3 times and it doesn’t connect
It could still have your old settings. They don’t necessarily get wiped depending on how you flash. If you hold down the reset button on the nodemcu, it will go back to AP mode and you can connect to WLED-AP and reconfigure.
I recorded 2 different firmwares, and it is in ap mode and does not configure on wifi
Na verdade peguei um esp32 que tava com o sistema funcionado liguei agora e não conecta também será que é algo com o roteador?
sorry, i wrote in brazilian portuguese
So it lets you connect in AP mode but doesn’t connect to the network later? Going out on a limb here, but do you have special characters in your network name?
Não funcionava antes, peguei outro roteador e funcionou
E acho que e meu roteador, mas não sei porque não aceita o login
