WLED SR version 0.13.2 - MQTT settings can not be saved
i’m not able to save any mqtt setting on my WLED SR 0.13.2. All the settings disappeared after the automatic reload of the page. I have restarted my EPS32 several times, I have also tried another broker but with the same result.
Does anyone have an idea how i can get MQTT to work ?
best Hagi
MQTT is disabled by default for SR builds , compile from source and enable it , however we have received note from SR dev team that " IR, MQTT and a few other functions were disabled in SR WLED to avoid performance issue " . Although I have enabled on test units without any apparent issues , it could an issue in your case or other areas I haven’t seen or tested . Cheers
