I’ve just done a fresh install of version v0.13.0-b6 because I wanted to use the infrared .json feature.
I tried following the wiki (config->Sync Interface) but I can’t seem to find the IR Setting as described.
Can someone point me in the right direction?
The docs are a little thin on where to find that although there’s a reference in the Sync section:
The default sensor pin is GPIO4. It can be changed in LED settings.
They’re configured under LED Preferences.
In the Hardware section just after the LED outputs definitions.
You’ll find Button, IR, and Relay GPIO configurations
